February 3, 2025 at 7:06 am
goktugh
SubscriberHello,
Recently, I am facing with some kind of problems about license server machine. I have connection with the server, the ping responses are normal and there is nothing strange about the general options. Additionally, I am using HFSS with that settings like 3 years but somehow I get some errors since last week and I can not solve it.
Can someone kindly help us about this issue? Thanks.
Best regards,
Goktug
RemotePort: 1055
TCPTestSucceeded: True
RemotePort: 2325
Reply from SERVER: bytes = 32 time=1ms TTL=127
lmgrd is not running: Lincese server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
February 4, 2025 at 10:48 am
Rajeshwari Jadhav
Ansys EmployeeHi,
Please launch your clientsettings.exe or licensingsettings.exe from "C:\Program Files\AnsysEM\v2xx\Win64\licensingclient\winx64", click on features in use tab, if it shows -96 error then follow below method.
Go to the start menu open the command prompt, and run the below-mentioned commands:
- ping servername
type this command and send the screenshot of the output.
- telnet servername portnumber
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
If above fails, then please check if license manager is up and running.
If above is a success, then please add entries in hosts file (take help from your IT team to add the server IP entry and save the hosts file which needs admin access)
- Open the HOSTS file on client machine and add the license server name and IP of the license server in that hosts file.
- Path: “ C:\Windows\system32\drivers\etc\hosts file “ as per the following format in your client machine :
- Path: For linux you can goto etc/hosts file (root access) and at the end add entries
Example:
IP address of server Hostname of server FQDN
xxx.xxx.xxx.xxx xxxxxx xxxxxx //replace x, IP address of server(will be mentioned in command when you perform ping servername) and name add in last line of hosts file.
- Once the entry is added save the file.
- Launch the Ansys application.
February 27, 2025 at 6:17 am
goktugh
SubscriberHello Rajeshwari,
I tried the things that you wrote, i still have the same problem.
I can take ping responses and telnet command gives me black screen. Also I added the entry and saved the file and launched the application.
Is there any other advices that you can give? Thanks in advance.
February 27, 2025 at 11:08 am
Rajeshwari Jadhav
Ansys EmployeeHi,
From server end verify if lmgrd and ansyslmd is added to the firewall. https://youtu.be/XIh47MZG__A?si=JXpKvGu0bmLi0ROo
Also what's the License Manager version?
February 27, 2025 at 11:16 am
goktugh
SubscriberHi, the license manager version is 2024. lmgrd and ansyslmd is not added to the firewall.
February 28, 2025 at 12:15 pm
Rajeshwari Jadhav
Ansys EmployeeHi,
Please add it on server end.
2788
965
851
599
591
