December 2, 2020 at 5:32 pmFlorianHenscheid1Subscriber
Hey Guys i am looking forward to calculate a LBA for cylindrical shells with different boundary conditions (bc1r, bc1f, bc2r and bc2f). The eigenvalues/eigenforms that i get for small shells (Lenght<300mm), however, do not look right and do not really converge. The code is attached as well as a picture of one eigenform.
Thanks
December 2, 2020 at 5:35 pmFlorianHenscheid1SubscribernnDecember 21, 2020 at 9:14 amAshish KhemkaForum ModeratornnPlease see if the following example helps:nnnRegards,nAshish KhemkanViewing 2 reply threads- The topic ‘LBA Cylindrical Shell (Steel) under torsional load’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1416
599
591
565
366
