Launching Transient Solver, process tdslink died unexpectedly. Please contact ANSYS technical suppor
October 28, 2021 at 5:34 pm
Kashish
SubscriberI am running a simulation to calculate an efficiency map for a SRM motor. I made the model in RMxprt, exported to Maxwell 2d and then ran it. I am getting the following error.
October 28, 2021 at 6:56 pmNovember 3, 2021 at 2:24 pmNKC
Forum ModeratorNovember 4, 2021 at 2:33 pmViewing 3 reply threads- The topic ‘Launching Transient Solver, process tdslink died unexpectedly. Please contact ANSYS technical suppor’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4152
1487
1318
1170
