Knee joint contact problem leading to convergence issues
    • krishna4339
      Dear @peteroznewman
      greetings of the day...i am trying to perform a static structural analysis of knee joint. My model involves 10 parts (including ligaments cartilage etc) and 13 contacts (frictional and bonded). To save time I tried to simplify the model and started experimenting on it.
      Mesh is created in Altair hypermesh software and it is exported as cdb file to Ansys wb.
      In ansys workbench i have created contacts,boundary conditions,loading.
      I went through all discussions on biomechanic contacts in this forum before writing to you.
      I also went through youtube tutorials by ansys learning page.
      I have tried the following with respect to contact.
      1. different formulations tried with different detection methods to get convergence.
      2. changing the normal stiffness inorder to achieve convergence.
      3. increasing the number of substeps to apply displacement load slowly to achieve convergence
      4. tried changing the behavior of contact as explained in youtube video by ansys learning page.
      5. contact interface treatment also tried to change.
      6. mesh is refined using solid 185 elements in hypermesh.
      7. Even after all these i am not able to get the convergence.. Can you help?
      8. i can send the simplified model to you.
      Thanks for your time and help. have a great day!.
    • krishna4339
      wb archive file attached
      I recommend the following to help convergence.
      Use more elements through the thickness. A minimum of 4 linear elements should be used through the thickness. There are several places where there is only one element across the thickness.
      Add Keyop(6)=1 to the Meniscus because that material is close to incompressible with a Poisson's Ratio of 0.49
      Add Keyop(6)=1 to the Cartilage because that material is close to incompressible with a Poisson's Ratio of 0.45
      Consider using Hyperelastic Material model for the Cartilage because that material has a low Young's Modulus.
    • krishna4339
      Dear Thanks for answers.
      Part 1:
      i cannot use more eleements at some of locations due to its dimensions. So i tried using higher order element solid 186.
      keyop(6)=1 is used for all parts.
      If i use hyperelastic material for cartilage i am afraid my solution will not converge, thats why i am testing with linear isotropic material.
      after following all your suggestions, solution now converges upto 0.7 second. after that it stops converging. i have given displacement loadsteps upto 1 sec and increasing load gradually.
      what else can be tried to improve convergence?
      Am i making any mistakes , please let me know..
      Part 2:
      In my original model i have around 12 lakh element. Inorder to reduce the elements, i want to model bones as rigid and apply rotational displacement load on them about a particular axis. How can I do that?
      I have both stl file and cdb files. Can i remove mesh belonging to bones from cdb and replace with bones stl file using space claim ? other wise workbench will not allow to define external mesh as rigid body behavior. I hope you understood the problem.
      Thank you once again, have a great day!!
      I started a discussion to demonstrate how to converge STL files into Geometry that you might find helpful.
      /forum/discussion/29718/convert-stl-of-knee-joint-to-geometry
      I plan to make more videos to show the cartilage, meniscus and ligaments.
      You can take your STL file and reprocess it to geometry then mesh with more elements through the thickness. Linear elements are more robust than quadratic elements for contact models.
      I have seen models with linear elastic material properties that stopped convergence at some point and after the material was changed to hyperelastic, converged to the end.
      You can make the bones rigid and use a rotational joint to rotate it about any axis you want. The joint is created with its own local Csys and you can put the origin anywhere and orient the Z rotation axis in any direction you want. The joint can be to ground or between two bodies.
    • krishna4339
      Thanks for inputs you have provided here in different posts. I could learn a lot of things from you. I made it a habit to follow your posts and youtube videos. Its very helpful. Best part is that i got the solution converged.
      Have a great day!!
    • krishna4339
      is it possible to mesh this component with hexa hedral mesh ?
    • krishna4339
      if not possible to mesh it using hexa, then i want to mesh it using tetra, but i want more layered mesh on the thickness.. how we can achieve that ?
      You can make edits in SpaceClaim to get this geometry ready for hex meshing. It will be easier if you slice the part up into sweepable pieces. A sweepable piece has exactly the same number of edges on the top and the bottom face.
      Is that the same geometry in the image as in the project archive a few posts above? If so, I can take a closer look. If not, you should upload a new archive with that geometry.
    • krishna4339
      Yes it is the same geoemtry as it is in the archive.
      Could you also suggest me what options in meshing can be used to achieve tetra hedral mesh? I need along the surface coarsal mesh and along thickness finer layered mesh.
      i tried with inflation it didnt work.
      thank you
    • krishna4339
      greetings of the day!
      i am facing problems during solution process.
      solution is not comverging after 0.3 seconds. (total time is 1 sec)
      i have attached solver output file.
      Could you please look into it and help?
      Thank you
      have a nice day!
    • krishna4339
      contact used : bonded(MPC FORMULATION) and frictional(NORMAL LAGRANGE).
      Analysis involves both rigid and deformable bodies.
      First there is a warning: Element 47783 (type = 11, SOLID185) (and maybe other elements) hasbecome highly distorted.Excessive distortion of elements is usuallya symptom indicating the need for corrective action elsewhere.Tryincrementing the load more slowly (increase the number of substeps ordecrease the time step size).You may need to improve your mesh toobtain elements with better aspect ratios.Also consider the behaviorof materials, contact pairs, and/or constraint equations.
      Then there is the error that stops the solution: Element 47783 (SOLID185) is turning inside out.
      Follow the advice given: Increment the load more slowly. That means in the step controls, try using: Initial Substeps = 100, Minimum Substeps = 100, Maximum Substeps = 1000.
    • krishna4339
      Greetings of the day.
      I have read in forum , where you said that its better to have shared topology than bonded contact or fixed joint between parts if possible as it would simplify the model to great extent. So I tried it. most of them worked but one of the contact it is not possible to define shared topology. I have attached the iges file. Could you look into it and help??? Thanks as always. Have a nice day.
      I'm traveling this weekend so won't be able to look at it until Monday.
    • krishna4339
      Attached is a SpaceClaim 2020 R2 document in a .7z archive.
      The file you start with has gaps between the two solids.
      The approach to making this work with Shared Topology is to copy the face from the bone, and rebuild the cartilage solid using that face and the side faces and the outer face. I have started that. Try and finish it yourself.
    • krishna4339
      greetings of the day peter
      how do we decide the perfect number of initial ,minimum and maximum substeps for the knee contact problem? i tried bigger steps got element distortion error, tried too small baby steps, so far converging. But in my 6 core machine it might take weeks to finish.
      Thanks
    • krishna4339
      attached a file below
    • krishna4339
      The analysis should run for 300 steps (300 seconds) Am i making any mistakes ? please guide. Also attached force convergence plot. Please help me to understand this analysis better.
      300 steps with a minimum of 20 substeps = 6000 load increments and the solver seems to be taking 4 iterations to converge each increment, so you can estimate 24,000 iterations. Measure the time per iteration. Multiply that by 24,000 to estimate the time to finish.
      You would be better off with just a few steps. That might allow the solver to take larger increments and reduce the total number of iterations.
      You should also see if you can reduce the time per iteration by using fewer nodes. See if the Direct Solver or the Iterative Solver takes less time per iteration.
    • krishna4339
      Dear peter, Greetings of the day.
      I am still learning alot of things with contact modeling. Now i tried a simple contact problem (Check snapshot). My question is how to get deformation results and contact pressure for both components. I have tried whatever I have learnt so far.I must be missing something.Could you take a look ??
      I have played around mesh,contact behavior,formulations , stepsize , even changed type of analysis to transient from static. Still no change.
      Thanks
      I don't know what result you are plotting or what the colors mean. You didn't include the legend in the image. Please provide an image that shows the legend.
    • krishna4339
      Sorry. I thought that may not be relevant. It is a deformation plot.
      attached here , update: when i changed the friction coefficient from 0.002 to 0.1 i got contact pressure on both contact and target faces. But why the deformation is only on one body? since they are having same material, shouldnt they deform by same amount wrt each other ??
      It looks like the moving body had to travel 1 mm before the fixed body made contact with it.
      Plot the contact pressure vs time.
    • krishna4339
      Why does it matter ? Even if it travels when they contact each have to deform wrt each other ... could u explain ?
      Deformation is relative to the starting location of each node, so it matters that one body travelled 1 mm before contact.
      Plot Strain to see the local deformation of each element with respect to its initial shape, regardless of how far it had to travel before contact was made. The same goes for Stress.
    • krishna4339
      How to enter prony series data which contains 3 paramters in ansys engineering data??
      snapshots attached are
      prony test data from literaure
      Equations used for the prony series. (its not maxwell model )
      ansys visco elastic table from engineering data
    • krishna4339
    • krishna4339
    • krishna4339
    • krishna4339
      with respect to above post in the help i was able to find that both bulk and shear moduli data to be entered seperately. But how to do it in engineering data ? also where to add initial young's modulus and poissons ratio ?
      Can you help?
      thanks
Viewing 32 reply threads
  • The topic ‘Knee joint contact problem leading to convergence issues’ is closed to new replies.
