Ansys Products
Ansys Products
Issue with ANSYS electronics desktop
    • ftse33
      Hello,I've been trying to connect my client desktop to a licensed server from another desktop but I am unable to open the program, ANSYS electronics desktop. I have created ports for 1055 and 2325 and created FLEXLM_TIMEOUT setting in both desktops. However when I try to open the electronics desktop this message pops up.Failover feature 'ANSYS electronics_desktop' specified in license preferences is not available.nI have done research in the Ansys forum, but I don't know if the problem is the %APPDATA% folder that everyone keeps referring to or something else. Also I am unable to find the %APPDATA% folder in my C drive. Thank you in advance. nF. Tse
    • ANSYS_MMadore
      Array Please open the %TEMP%\.ansys\licdebug.ANSYSEDT.EXE.XXX.out, where XXX is the version you are running. Please share the FULL contents of the file.nnYou may also need to set your ansyslmd process to use a static port. To do this, open the license file on the license server and add PORT=1056 to the VENDOR line of the header.nExample:nVENDOR ansyslmd PORT=1056nThen restart the license manager and create a firewall exception for port 1056.nnThanksnMattn
    • ftse33
      Array Thank you for the reply. However I do not know were to find the file that you are requesting, %TEMP%\.ansys\licdebug.ANSYSEDT.EXE.XXX.out.nAlso I don't know where to add the line, VENDOR ansyslmd PORT=1056 in my license txt file.nnPlease see below the first part of my license server file.n-------------------------------------------- NORMAL STARTUP 2021/01/12 15:18:28 ---------------------------------------------nttnttANSYS Licensing Interconnect version 2.2.1 (20201116) for winx64. Updated at ANSYS Release 2021 R1. Started on 2021/01/12 15:18:28 by SYSTEM@Steamwhistle.corp.c-intech.com:winx64 with pid 6600.ntt(C) 2021 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited.nttBuilt Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6nttBuilt Using OpenSSL 1.1.1g 21 Apr 2020nntt-----------------------------------------------------------------------------------------------------------------------------nnttPlease note that entries in this debug log have the following format:nnTIMESTAMP       ACTION       FEATURE          REVISION (BUILD DATE)       A/B/C/D         W/X/Y/Z  PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY                  SOCKET:IP      nnttLicenses statistics:ntt--------------------nttA is the number of licenses requested by this ACTION.nttB is the number of licenses used by this USER.nttC is the number of licenses used by all users.nttD is the number of licenses available in the local license pool.nnttLicense server performance statistics:ntt--------------------------------------nttW is the number of currently connected client applications.nttX is the maximum number of connected client applications.nttY is the unique serial number of this client application.nttZ is the number of all client applications served by this Licensing Interconnect server.nnF. Tse n
    • ANSYS_MMadore
      Array The license to be modified is on the machine running the license manager, C:\Program Files\Ansys Inc\Shared Files\Licensing\license_files\ansyslmd.lic.nnThe file I requested can be found by opening a file explorer window and typing %TEMP%\.ansys without the quotes. It will be in that directory.n
    • ftse33
      2021/01/12 13:32:44  DENIED       q3d_desktop           21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttRequest name q3d_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    q3d_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:44  DENIED       FEAT_Q3D_DESKTOP        21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttFailover feature 'Q3D desktop environment' is not available.nttRequest name q3d_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    q3d_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:44  DENIED       maxwell_desktop         21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttRequest name maxwell_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    maxwell_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:44  DENIED       FEAT_MAXWELL_DESKTOP      21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttFailover feature 'Maxwell Interface Desktop' is not available.nttRequest name maxwell_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    maxwell_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:44  DENIED       simplorer_desktop        21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttRequest name simplorer_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    simplorer_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:44  DENIED       FEAT_SIMPLORER_DESKTOP     21.1 (2020.1029)       1/0/0/0         1/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistle.corp.c-intech.com:winx64  7984:192.168.10.174 nttFailover feature 'Simplorer Desktop' is not available.nttRequest name simplorer_desktop does not exist in the licensing pool.nttCannot connect to license server system.ntt The license server manager (lmgrd) has not been started yet,ntt the wrong port@host or license file is being used, or thentt port or hostname in the license file has been changed.nttFeature:    simplorer_desktopnttServer name:  192.168.10.174nttLicense path: 1055@STEAMWHISTLE;nttFlexNet Licensing error:-15,10. System Error:10061 WinSock:Connection refusedn2021/01/12 13:32:47  CLIENT_EXIT                                               0/1/1/1  10492:ANSYSEDT.EXE:Brian@Steamwhistlen
    • ftse33
      I found both files, however when I try to save license file, I do not have permission to open the file and it gives me an error to save.n
    • ANSYS_MMadore
      You may need to save it to your desktop, then copy it and replace the existing copy to address the permissions issue.nnIt looks like setting the port and adding the exception should work.nnThanks,nMattn
    • ftse33
      Array Thank you so much for helping me out today. I really appreciate it and have an amazing day! nFlora Arrayn
Viewing 8 reply threads
  • The topic ‘Issue with ANSYS electronics desktop’ is closed to new replies.
