Electronics
Electronics
Issue in Siwave simulation after importing the SNP file
    • sunjianwudi19870311
      Hello everyone,
      I’m having an issue while simulating with Siwave.
      Let me first provide some background:
      This is what our OBD++ looks like when opened in Siwave; the component in the red box is a TDK low-pass filter.
      I have the S2P file for this LPF, and I simulated it in ADS. This LPF has excellent insertion loss.
      I now want to import this S2P file into Siwave and disable all the capacitors and inductors connected to this device, adding a port at each end.
      Here are the steps I follow to import S2P file.
      Next, I set the frequency range for the simulation.
      After simulation, an S2P file was generated, which was opened in ADS.
      The insertion loss is surprisingly high.
      Next, I wondered if there might be a problem with the traces at either end, so I simulated each trace separately and checked the results in ADS.
      Trace 01
      Trace 02
      Based on the simulation results, there are no issues with these two traces.
      So I connected the S2P files for these two traces and the LPF’s S2P file in ADS to view the overall S-parameters.
      The results are significantly better than the S-parameters obtained from direct simulation in Siwave.
      Right now, I'm really eager to figure out exactly where the problem lies. I've been checking it for several days now, but I still can't find the cause.
      Could anyone help me?
Viewing 0 reply threads
