Electronics
Electronics
Is there anyway to directly add the grade of permanent magnet?
    • s3740222
      HI,nIs there any way, I can add a grade of the permanent magnet in the ANSYS maxwell project. I can define material NdFeB and set the directions. But I don't know how to add grades like N50, N52 or so. I tried adding properties of N50 material but there is no option of adding exactly the properties available for N50 magnet.nn
    • Navya Chode
      nWhich properties are you not able to add to the material definition?nThere can be mechanical properties that are not relevant for Maxwell simulation.nCan you mention which properties are you trying to add for a new material definition?nExplain with some screenshots for better interpretation of the problemnnRegards,nNavyan
  • The topic ‘Is there anyway to directly add the grade of permanent magnet?’ is closed to new replies.
