Is the result exactly correct result for modal analysis ?
    • muhammadagussriharto
      Hi, guys. I just wanna ask something relate to my model and the result is appropriate accurately even though there's need experiment to get "actual result"
      So, Let's start .
      I cofidently at beginning when I solve the holllow beam I made and the settings have been made . but there's something a little make me not put confident  on that . You may like ask , where and when?
      Look image on the below:
      minimum occurs on: Midsurfaces 1
      maximum occurs on: Midsurfaces 2
      If the "occurs" happen different side , so I predict the result of deformation not correct  or inaccurately.
      I assume THAT WIL BE CORRECT if the minimum occurs and maximum occurs happen on one side "only'
      So , is there any advice or opinion for that . I really need help .
      at below the geometry look like . btw , I'm using midsurface because thin structure .
    • erik.kostson
      See this post that explains some important aspects/points of modal analysis.
      https://innovationspace.ansys.com/forum/forums/topic/unreasonable-behavior-of-a-structure-during-a-modal-simulation-2/
      I would also suggest to take our free modal analysis course (search under courses):
      https://innovationspace.ansys.com/product/modal-analysis/
      All the best
      Erik
