Is that possible to combine VOF, Species and Solification&Melting models together?
    • wuxuetianzi
      I am wondering if that is possible to combine VOF, Species and Solification&Melting models together?
      Because the UDFs are working well when only the species model activated. However, after the VOF and solidification model activated, (The geometry is a little bit different, but most of them are same)
      This problem happened. I know there is something wrong with UDFs,  but first I want to know if they can work together and the UDFs will be coded differently while three models activated?
      Thank you so much if anyone can help me.
      Best
      That combination should work. What does the UDF do?
    • wuxuetianzi
      Thank you for your reply. So far, The UDFs are used in diffusivity, and surface reaction rate.
      Check which phase the UDF interacts with and how materials/energy is added into the domain.
  • The topic ‘Is that possible to combine VOF, Species and Solification&Melting models together?’ is closed to new replies.
