Photonics
Photonics
Inverse design with FDTD and Python API in a headless Linux HPC system
    • jmidkiff
      Hello. I am doing inverse design with FDTD and the Python API. On my local machine I use the GUI to launch the python script SWDM.py and everything runs fine, albeit very slowly. I would like to speed up the optimization process by running it on a high-performance computing (HPC) system. I have Lumerical v242 installed on a Rocky Linux HPC system (without a GUI) called Lonestar6. I am able to run a single simulation file SWDM.fsp utilizing the Slurm job script SWDM_one_sim.txt.
      Now, I have tried to create a Slurm job script SWDM_optimize.txt which calls out the Python script SWDM.py. However, when I try to run it, it seems that some of the settings declared in the job script are not recognized during execution of the Python script. As I am new to HPC, surely I am missing something. I would like to know if you have any ideas or suggestions to make this work? The files SWDM_one_sim.txt, SWDM_optimize.txt, SWDM.py, and SWDM_error.log are provided below. Thanks.
      SWDM_one_sim.txt
      #!/bin/bash
      #SBATCH -J SWDM              # Job name
      #SBATCH -o SWDM_out.log      # Standard output log
      #SBATCH -e SWDM_err.log      # Standard error log
      #SBATCH -p normal            # Queue/partition name
      #SBATCH -N 1                 # Number of nodes
      #SBATCH -n 1                 # Total number of tasks
      #SBATCH --cpus-per-task=8    # Number of cores/threads (should match -t flag)
      #SBATCH --mem=1024           # Memory (in MB)
      #SBATCH -t 00:10:00          # Runtime (hh:mm:ss)
      #SBATCH -A PHY25016          # Lonestar6 allocation
      # Load modules
      module reset
      module load intel/19.1.1
      module load impi/19.0.9
      # Set path to libglut.so.3 (from user gda)
      export LD_LIBRARY_PATH=/home1/01249/gda/test/glut/usr/lib64:$LD_LIBRARY_PATH
      # Set Ansys licensing environment variable
      export ANSYSLMD_LICENSE_FILE=XXXX
      # Set Ansys Lumerical API and bundled Python3 path
      export PATH=/work/10565/jmidkiff/opt/lumerical/v242/bin:/work/10565/jmidkiff/opt/lumerical/v242/python/bin:$PATH
      export PYTHONPATH=/work/10565/jmidkiff/opt/lumerical/v242/api/python:$PYTHONPATH
      set -e
      # Run a single FDTD simulation
      fdtd-engine-impi-lcl -t 8 SWDM.fsp
      SWDM_optimize.txt
      #!/bin/bash
      #SBATCH -n 4                 # Total number of tasks
      # Load any necessary modules
      module reset
      # Set hidden CAD (Required for Lumerical script, Python API, LumOpt)
      export QT_QPA_PLATFORM=offscreen
      set -e
      # Run Python optimization script
      python3 SWDM.py
      SWDM.py
      ######## IMPORTS ########
      # General purpose imports
      import os
      import sys
      import numpy as np
      # Optimization specific imports
      from lumopt import CONFIG
      from lumopt.geometries.topology import TopologyOptimization2D
      from lumopt.utilities.load_lumerical_scripts import load_from_lsf
      from lumopt.figures_of_merit.modematch import ModeMatch
      from lumopt.optimization import Optimization
      from lumopt.optimizers.generic_optimizers import ScipyOptimizers
      from lumopt.utilities.wavelengths import Wavelengths
      ######## DEFINE BASE SIMULATION ########
      def runSim(params, eps_bg, eps_wg, x_pos, y_pos, size_x, size_y, filter_R, working_dir, beta):
          ######## DEFINE GEOMETRY ########
          geometry = TopologyOptimization2D(params=params, eps_min=eps_bg, eps_max=eps_wg, x=x_pos, y=y_pos, z=0, filter_R=filter_R, beta=beta)
          ######## DEFINE FIGURE OF MERIT FOR EACH OUTPUT WAVEGUIDE ########
          fom1 = ModeMatch(monitor_name = 'fom_1', mode_number = 'Fundamental TE mode', direction = 'Forward', norm_p = 2, target_fom=1)
          fom2 = ModeMatch(monitor_name = 'fom_2', mode_number = 'Fundamental TE mode', direction = 'Forward', norm_p = 2, target_fom=1)
          ######## DEFINE OPTIMIZATION ALGORITHM ########
          optimizer = ScipyOptimizers(max_iter=400, method='L-BFGS-B', pgtol=1e-6, ftol=1e-5, scale_initial_gradient_to=0.25)
          ######## DEFINE SETUP SCRIPT AND INDIVIDUAL OPTIMIZERS ########
          script = load_from_lsf('SWDM.lsf')
          wavelengths1 = Wavelengths(start = 834e-9, stop = 848e-9, points = 6)
          opt1 = Optimization(base_script=script, wavelengths = wavelengths1, fom=fom1, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=True, plot_history=False, store_all_simulations=False, save_global_index=False)
          wavelengths2 = Wavelengths(start = 860e-9, stop = 938e-9, points = 7)
          opt2 = Optimization(base_script=script, wavelengths = wavelengths2, fom=fom2, geometry=geometry, optimizer=optimizer, use_deps=False, hide_fdtd_cad=True, plot_history=False, store_all_simulations=False, save_global_index=False)
          ######## PUT EVERYTHING TOGETHER AND RUN ########
          opt = opt1+opt2
          opt.continuation_max_iter = 30 #< How many iterations per binarization step (default is 20)
          opt.run(working_dir = working_dir)
      if __name__ == '__main__':
          size_x = 9000
          size_y = 4000
          filter_R = 200e-9
          x_points=int(size_x/20)+1
          y_points=int(size_y/20)+1
          eps_wg = 1.74**2
          eps_bg = 1.45**2
          x_pos = np.linspace(-size_x/2*1e-9,size_x/2*1e-9,x_points)
          y_pos = np.linspace(-size_y/2*1e-9,size_y/2*1e-9,y_points)
          ## Initial condition:
          params = 0.5*np.ones((x_points,y_points))     #< Start with the domain filled with (eps_wg+eps_bg)/2
          beta = 1
          working_dir = 'SWDM_x{:04d}_y{:04d}_f{:04d}'.format(size_x,size_y,int(filter_R*1e9))
          runSim(params, eps_bg, eps_wg, x_pos, y_pos, size_x*1e-9, size_y*1e-9, filter_R, working_dir=working_dir, beta=beta)
      SWDM_error.log
      Traceback (most recent call last):
        File "/work/10565/jmidkiff/SWDM.py", line 78, in
        File "/work/10565/jmidkiff/SWDM.py", line 50, in runSim
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumopt/optimization.py", line 471, in run
          self.initialize(working_dir=working_dir)
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumopt/optimization.py", line 119, in initialize
          self.one_forward = check_one_forward_sim(self.optimizations[0])
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumopt/optimization.py", line 82, in check_one_forward_sim
          co_opt.sim = Simulation(self.workingDir, co_opt.use_var_fdtd, co_opt.hide_fdtd_cad)
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumopt/utilities/simulation.py", line 22, in __init__
          self.fdtd = lumapi.MODE(hide = hide_fdtd_cad) if use_var_fdtd else lumapi.FDTD(hide = hide_fdtd_cad)
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumapi.py", line 1541, in __init__
          super(FDTD, self).__init__('fdtd', filename, key, hide, serverArgs, remoteArgs, **kwargs)
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumapi.py", line 1196, in __init__
          handle = self.__open__(iapi, product, key, hide, serverArgs, remoteArgs)
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumapi.py", line 1415, in __open__
          raise LumApiError(error)
      lumapi.LumApiError: 'appOpen error: \n Failed to start messaging, check licenses.../work/10565/jmidkiff/opt/lumerical/v242/bin/fdtd-solutions-app: error while loading shared libraries: libglut.so.3: cannot open shared object file: No such file or directory\n'
      Exception ignored in:
        File "/work/10565/jmidkiff/opt/lumerical/v242/api/python/lumopt/utilities/simulation.py", line 67, in __del__
          self.fdtd.close()
      AttributeError: 'Simulation' object has no attribute 'fdtd'
      SWDM_out.log
      CONFIGURATION FILE {'root': '/work/10565/jmidkiff/opt/lumerical/v242/api/python', 'lumapi': '/work/10565/jmidkiff/opt/lumerical/v242/api/python'}
      Initializing super optimization
      Checking for one forward simulation :
    • Taylor Robertson
      So in the first case you are running the FDTD engine on a file, which is straightforward on a headless cluster.
      With the python api in the second case you need to use lumerical gui which can be a bit more complicated. Make sure you set these environment variables correctly.
      Running-CAD-jobs-on-headless-Linux-systems
      From what you shared I think the issue is something I have seen before, and it appears to a dependecies issue.
      See this page for how to resolve it. The issue happens when installing without root access or not using the default install process using our script 'install.sh'. This lumerical install.sh script with root access will check for dependencies and download and install them together with Lumerical.
      Best Regards,
