April 2, 2024 at 8:42 pm
fa146088
SubscriberDear all,I downloaded the "inverse design y-branch" simulation file provided on the website and ran it. However, the issue is that the transmission plot shown on the website (please find the attachment), where the transmission is almost 1 for a range of wavelengths from 1300nm to 1800nm, cannot be the same as what I obtained (please see the second attached photo).I would appreciate it if you could assist me.Best regards,FK -
April 3, 2024 at 8:52 pm
Guilin Sun
Ansys EmployeeIt seems you are simulating 3D FDTD, right?
where is the port source and where is the transmission monitor? in one port or it covers both ports on the right?
April 5, 2024 at 2:26 pm
fa146088
Subscriberyes, I am.
The port source is located in the left side and the monitor is located in the right side which covers both ports.
April 5, 2024 at 3:49 pm
Guilin Sun
Ansys EmployeeFor the 3D case, I did not duplicate the results either. Maybe something was changed. we need time to dig up.
April 5, 2024 at 8:28 pm
fa146088
SubscriberI appreciate your support and response.
May 4, 2024 at 1:53 am
fa146088
SubscriberI wonder, could you find the problem with what happened to the transmission?”
May 6, 2024 at 3:46 pm
May 10, 2024 at 4:55 pm
fa146088
SubscriberThank you very much, my problem has been solved.
Viewing 5 reply threads
- The topic ‘Inverse design of y-branch’ is closed to new replies.
