Electronics
Electronics
interconnection between ansys maxwell and matlab simulink
    • d-tve21jan004
      hi, currently I am working with design and simulation of linear motor in Ansys Maxwell. I have done the modelling of power electronic circuit and control circuitry for V/f control in matlab simulink. Could any one can support me for interconnecting MATLAB simulink circuit with Ansys Maxwell software.
    • Navya Chode
      Hi d-tve21jan004,
      You can follow the below steps if you want to connect your Matlab circuit to the Maxwell excitations.
      1. Change all the excitations in Maxwell to external
      2. Right-click on “Excitations”, then select “Setup Co-Simulation with Simulink...”.
      3. Click “Import Circuit...” and locate .slx file.
      4. Click OK to finish the setup and run the simulation.
      Refer to Matlab optimizer section in the Maxwell Help for more details on compatibility and optimization
      Navya
  • The topic ‘interconnection between ansys maxwell and matlab simulink’ is closed to new replies.
