August 24, 2024 at 7:38 pm
Arusakshi Dighe
Subscriber Ansys Mechanical Enterprise Academic Student    Â
 ANSYS LICENSE MANAGER ERROR:
 Insufficient FlexNet Publisher (FNP) license count of HPC Parallel are available for use, only 4 of the requested 6 tasks were available.
 No FlexNet Publisher (FNP) license found for feature HPC Parallel.
            FNP license path: C:\Users\Lenovo\AppData\Local\Temp\\055202d6-ceea-46c4-8160-a55269c9cfe0
 *** ERROR - Insufficient HPC licenses available.
whybad=Â Â Â Â Â Â Â Â Â -5
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2024 R2Â Â Â Â Â Â Â Â Â Â Â Build: 24.2Â Â Â Â Â Â Update: UP20240513Â Â Platform: WINDOWS x64
Date Run: 08/25/2024Â Â Time: 00:47Â Â Â Â Process ID: 32888
Operating System: Windows 11Â (Build: 22631)
Processor Model: 11th Gen Intel(R) Core(TM) i5-11320H @ 3.20GHz
Compiler: Intel(R) Fortran Compiler Classic Version 2021.9Â (Build: 20230302)
         Intel(R) C/C++ Compiler Classic Version 2021.9 (Build: 20230302)
         Intel(R) oneAPI Math Kernel Library Version 2023.1-Product Build 20230303
Number of machines requested           :   1
Total number of cores available        :   8
Number of physical cores available     :   4
Number of processes requested          :   2
Number of threads per process requested :Â Â Â 1
Total number of cores requested        :   2 (Distributed Memory Parallel)             Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.11 for Windows* OS
Number of GPUs requested               :   2
GPU Acceleration: NVIDIA Library Requested but not Enabled
GPU Device with ID =Â 0 is: NVIDIA GeForce GTX 1650
GPU Driver Version: 12.0
CUDA Version: 12.0
Job Name: file0
 Core               Machine Name  Working Directory
    0                  Arusakshi  C:\Users\Lenovo\AppData\Local\Temp\WB_Lenovo_24424_2\_ProjectScratch\ScrB759
    1                  Arusakshi  C:\Users\Lenovo\AppData\Local\Temp\WB_Lenovo_24424_2\_ProjectScratch\ScrB759
Total CPU time for main thread                   :       0.1 seconds
Total CPU time summed for all threads            :       0.0 seconds
Elapsed time spent obtaining a license           :       0.5 seconds
Elapsed time spent pre-processing model (/PREP7)Â :Â Â Â Â Â Â Â 0.0 seconds
Elapsed time spent solution - preprocessing      :       0.0 seconds
Elapsed time spent computing solution            :       0.0 seconds
Elapsed time spent solution - postprocessing     :       0.0 seconds
Elapsed time spent post-processing model (/POST1) :Â Â Â Â Â Â Â 0.0 seconds
Sum of disk space used on all processes          :       0.0 MB
Sum of memory used on all processes              :       4.0 MB
Sum of memory allocated on all processes         :       0.0 MB
Physical memory available                        :         8 GB
Total amount of I/O written to disk              :       0.0 GB
Total amount of I/O read from disk               :       0.0 GB
+------------------ E N DÂ Â M A P D LÂ Â S T A T I S T I C S -------------------+
 |                              RUN COMPLETED                                |
 | Ansys MAPDL 2024 R2        Build 24.2        UP20240513   WINDOWS x64  |
 | Database Requested(-db)    1024 MB    Scratch Memory Requested     0 MB |
 | Max Database Used(Master)     1 MB    Max Scratch Used(Master)     1 MB |
 | Max Database Used(Workers)    1 MB    Max Scratch Used(Workers)    1 MB |
 | Sum Database Used(All)        2 MB    Sum Scratch Used(All)        2 MB |
 |       CP Time     (sec) =         0.016      Time = 00:47:38         |
 |       Elapsed Time (sec) =         5.000      Date = 08/25/2024       |
August 26, 2024 at 10:51 am
Mrunali Barde
Ansys EmployeeHello Arusakshi,Â
Can you please confirm if your laptop/workstation supports using more than 4 cores?
Can you also check if HPC pack/pool licenses are available for use?
Can you try using cores/process = 4 and let me know if it works?
Wishes,Â
Mrunali. -
August 26, 2024 at 3:14 pm
George Karnos
Ansys EmployeeHello,
If this is the Free Student version, set # of cores to 4 max and set Number of GPU Requested to 0
Free Student version is limited.
Ansys HPC (High-Performance Computing):
Support up to four CPU cores of HPC solutions and 40 SMs of GPU computing on FluentBest Regards,
George Karnos-
August 27, 2024 at 10:16 am
Arusakshi Dighe
Subscriberyeess it works now thankyou so much for the help.
- The topic ‘Insufficient HPC licenses available.’ is closed to new replies.
4612
1515
1386
1209
