August 19, 2019 at 10:31 am
dvankran
SubscriberI am trying to install the 2019 R2 software, but every time it the install gives the following error message. I have tried disabling all firewalls during the install but to no avail. Any recommendations?
August 19, 2019 at 10:32 am
dvankran
SubscriberANSYS installation: Sun Aug 18 11:55:43 2019
Revision: 2019 R2
  ###### Error #######
  Error executing configuration script 'C:UsersdvankAppDataLocalTempans_install_tmp3708
configAnsConfigCommon.tcl'
  '"C:UsersdvankAppDataLocalTempans_install_ tmp3708tclbinwinx64tclsh. exe" "C:UsersdvankAppDataLocal Tempans_install_tmp3708 configAnsConfigCommon.tcl"  -installdir "C:Program FilesANSYS Inc" -rev 194 -dotrev 2019 R2 -scripttosource "C:UsersdvankAppDataLocal Tempans_install_tmp3708 configConfigCommon.tcl" -sourcedir "C:UsersdvankAppDataLocal Tempans_install_tmp3708" -os_lang en-us -install ' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
  child killed: segmentation violation
    while executing
  "exec $cmdPath -install"
    invoked from within
  "if { $config == 1 || $unconfig == 1 } {
   set config_dir "$installDir\v$revn\commonfiles\configs"
   if { [ string compare -nocase "$env(ANSYS_SYS..."
    (file "C:UsersdvankAppDataLocalTempans_install_tmp3708 configAnsConfigCommon.tcl" line 25) -
August 19, 2019 at 5:03 pm
tsiriaks
Ansys EmployeeWhat is the output ofÂ
set
from CMD Prompt ?
Thanks,
Win
August 20, 2019 at 10:28 am
dvankran
SubscriberHi, please find it attached
August 20, 2019 at 10:58 am
Forum ModeratorPlease post into the message: staff are not permitted to open attachments.Â
August 21, 2019 at 12:58 am
dvankran
SubscriberI tried that first, but it wouldn't let me post
August 21, 2019 at 1:03 am
tsiriaks
Ansys Employeeyou can do it like this
type the following in CMD Prompt
set > C:tempset.log
this will create 'set.log' file under C:temp folder. Open that file with notepad or something, then copy the content of it (text) and paste it into this post.
Thanks,
Win
August 21, 2019 at 1:05 am
dvankran
SubscriberYeah I didn't have a problem getting the text into the post, it just wouldn't let me submit the post
August 21, 2019 at 9:16 pm
tsiriaks
Ansys Employeeoh I see.
Hmm... can you try posting the 'inline image' of the screenshot of this output again ?Â
Thanks,
Win
August 23, 2019 at 4:52 am
August 24, 2019 at 12:47 am
tsiriaks
Ansys EmployeeIt's odd that you get segmentation violation from this.
What if you create a test Windows user account like 'abc' (without quote), then reinstall it with 'run as administrator' (make sure you first wipe out C:Program FilesANSYS Inc and E:Program FilesANSYS Inc  folders)
August 25, 2019 at 1:35 am
dvankran
SubscriberI've tried the install on 3 different computers, it gives the same error each time
August 26, 2019 at 6:10 pm
tsiriaks
Ansys Employeeare you using same username for all of these ?
What is the default directory when you launch CMD Prompt ?
Do you have any anti-virus or security software running ? Can you try disabling them for a quick test ?
August 27, 2019 at 12:07 am
dvankran
SubscriberI am not using the same username for all of these. The default directory is C:Usersdvank. I have tried disabling all anti-virus when installing, and have obtained the same result each time.
August 27, 2019 at 6:39 pm
tsiriaks
Ansys EmployeeJust to confirm, you run the 'setup.exe' with 'run as administrator', right ?
Do you have enough disk space in C drive ?
Can you scan hard disk to see if there is any bad sector ?
August 27, 2019 at 10:13 pm
dvankran
SubscriberYes I'm running as admin, and yes there is enough space. Ivee tried installing on 3 different computers and 4 different hard drives, I highly doubt there's issues with all of them -
August 27, 2019 at 10:56 pm
tsiriaks
Ansys Employeeare you using exact same copy of installation package on all these machines ? If so, right click on your 'unzipped' installation package -> Properties , then post screenshot here
- The topic ‘Install segmentation violation’ is closed to new replies.
4728
1565
1386
1242
