September 19, 2024 at 8:12 am
qjaxod13
SubscriberHello,
I am a graduate student who primarily uses Ansys FLUENT.
I would like to conduct an LES simulation.
Based on publicly available materials I found on Google (Quick Guide to Setting Up LES-type simulations, Version 1.4, May 2016), I would like to initialize my LES simulation using RANS steady-state results.
According to the reference, the following TUI command can be used for this setup:
/solve/initialize/init-instantaneous-velHowever, in the version of FLUENT I am using (24R2), I cannot find
init-instantaneous-velunder the/solve/initializemenu.Could you please explain how I can perform unsteady initialization in this case?
Thank you in advance for your assistance.
September 19, 2024 at 10:51 am
Forum ModeratorI suspect you just switch model and it'll pick up the relevent field values - just checking with a colleague.Â
September 20, 2024 at 10:25 am
Forum ModeratorOK, the TUI (and back end maths) has been revised. Save case & data before using the TUI command as you can't change back.Â
/solve/init-turb-vel-fluctuationsÂ
should be the equivalent.Â
September 21, 2024 at 3:48 am
qjaxod13
SubscriberI finally solved it! Thank you so much! Have a great day! :)
October 3, 2024 at 1:13 pm
October 3, 2024 at 1:38 pm
Forum Moderatorhttps://innovationspace.ansys.com/forum/forums/topic/inquiry-regarding-les-initialization-in-fluent-24r1/
- The topic ‘Inquiry Regarding LES Initialization in FLUENT 24R2’ is closed to new replies.
5629
1885
1403
1298
