January 13, 2025 at 7:26 pmsin38Subscriber
I'm trying to do a LPBF additive manufacturing simulation using Inherent Strain. When I activate the "Scan Pattern" option in "Inherent Strain Defenition" and run the model, I get this error:
Failed to read AM strain shrinkage data.What am I doing wrong?
January 14, 2025 at 8:16 pmJohn DoyleAnsys Employee
The error message could be related to issues with the AMResults.txt file where the data for Structural AM analyses is written. This file includes the z-deformation of a layer just before a new layer is applied and is crucial for identifying potential issues when spreading a new layer. If the software is unable to read this data, it could be due to problems with the generation or saving of the data during the simulation process, or issues with accessing the AMResults.txt file correctly. To resolve this, you should check that the simulation is set up to generate this data and that the file is not corrupted or inaccessible.Â
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
1416
599
591
565
366
