April 2, 2020 at 4:23 pm
1brah1M
SubscriberDear All,
I hope you are doing well, Could you please help me to find a way to improve my results,
I am doing simulation for a ship multiphase VOF and SST model has been chosen,
The boundary Inlet Pressure inlet
Outlet Pressure Outlet
The ship is a wall
The Atm is set as pressure outlet
but the results do not converge.
Could you please tell me how can I improve it I have attached a file for the simulation
Best Regards
April 2, 2020 at 4:24 pm
April 2, 2020 at 5:13 pm
Karthik Remella
AdministratorHello,
Please run a transient simulation for this. This is a transient phenomenon and does not achieve a steady solution. Please adjust your timestep and number of iterations so you are converging every time-step.
Thanks.
Best,
Karthik
April 2, 2020 at 5:16 pm
1brah1M
Subscriberthanks, I will try it
April 2, 2020 at 5:27 pm
Amine Ben Hadj Ali
Ansys EmployeeSlso try to improve the mesh near the free sea level and increase mesh density along the hull. This can be done with steady state solver(only if final result is important..) but as my colleague said it is safer to run with transient solver to get evolving free surface level and loads accurately. -
April 3, 2020 at 7:31 am
1brah1M
SubscriberThanks for your kind reply, there is no possibility to improve the mesh due to limitation of student version, even the transit doesn't give any good results
any suggestions?
Best Regards
April 5, 2020 at 10:28 pm
Karthik Remella
AdministratorHello,
Could you please post some details about how you are setting up your model - boundary conditions, solver settings, and initial conditions?
Also, what is the quality of your mesh? Please provide the skewness value from Ansys Meshing.
Without this information, we might only be able to make some guesses as to why your model is diverging. Please share some elaborate screenshots in your next post.
Thank you.
Best,
Karthik
April 6, 2020 at 9:57 pm
1brah1M
SubscriberDear Kremella,
Thanks for your reply, yes sure skewness ave is 0.21743, max is 0.825,
For the model, I used SST model for the viscosity and VOF for multiphase using the open channel,
The boundary condition Inlet with Inlet pressure I set up the level of the water and the velocity,
Outlet Pressure Outlet.
I have attache the file that is make you able to check the case please find it ,
Best Regards
- The topic ‘Improving the results’ is closed to new replies.
4999
1675
1386
1248
