Ansys Products
Ansys Products
Importing Solidworks file to Fluent
    • Tom Davies
      I'm trying to import a 2D geometry from Solidworks, all fully defined but are two separate pieces, into fluent. Tried different file types but each time I'm getting a error and warning. Any suggestions?
    • Nilay Pedram
      Did you try importing it as a STP file?
      • Tom Davies
        Yes, I tried part, step and IGES
    • V.P
      Hi Tom,
      I think you can import 2D geometries. Just make sure that surface and line bodies are on the xy plane (SOLIDWORKS Reader (*.sldprt, *.sldasm) (ansys.com)
      You can also import Solidworks sketches in Workbench, but you will need to change 'Mixed Import Resolution' in geometry cell properties. Right-click on geometry cell and then choose properties. Here in the list of properties you can find 'Mixed Import Resolution' option.
      • Tom Davies
        Thank you, I will try the mixed import resolution approach.
  • The topic ‘Importing Solidworks file to Fluent’ is closed to new replies.
