April 9, 2024 at 3:04 pm
April 10, 2024 at 10:14 am
Ashish Khemka
Forum ModeratorHi,
Shell is is a surface body. What if you select surface instead of the body?
Ashish Khemka
April 10, 2024 at 3:51 pm
AR
SubscriberThere is no option to select surfaces because it is a body load (load/unit volume).
Even though the shell is a surface body - it has a volume & mass etc. due to its thickness. So we should be able to apply body loads to it. For example, Ansys allows gravity/acceleration loads to be applied to shell bodies based on their elemental mass.
Another scenario, is it possible to map the EM loads coming from Maxwell to the shell bodies? Basically, I am trying to do the same thing. Except that my EM loads are coming from an external solver as a point cloud.
April 11, 2024 at 12:47 pm
Ashish Khemka
Forum ModeratorHi,
You can map the loads using External Data module. Please see if the following link helps: External Data (ansys.com)
Ashish Khemka
- The topic ‘Importing Body Force Density to Shell Bodies’ is closed to new replies.
5824
