January 27, 2022 at 5:58 am
brc7
SubscriberHi,
I'm trying to convert a Cadence APD file (.mcm) to aedt from command prompt without opening the GUI. I am able to load the tool using "
which brings up GUI and shows the import options but that's as far as I can go right now.ansysedt.exe" I would like to import mcm file automatically and save it as .aedt file in a custom location without opening the GUI. I could not figure out much from HFSS help document in ansysedt options. I tried -ng -batchsave/-batchextract/autoextract options but to no avail. Is there a way to do achieve this requirement?
Note: Cadence file import seems to be using extracta tool.
Thanks!
February 1, 2022 at 11:35 amAncS
Have you gone through the "Running Ansys Electronics Desktop from a Command Line" section of the HFSS help document?
Do check the command format and other options there.
All the very best.
Regards
Anchal
February 1, 2022 at 3:39 pmbrc7
I did go through the section you mentioned but unfortunately the options specified doesn't solve my problem. I may need to look at HFSS scripting guide to see if such option exists.
Thanks!
Viewing 2 reply threads- The topic ‘Import Cadence APD (.mcm) file to ansysedt tool and save as .aedt using command prompt’ is closed to new replies.
6635
1312
