July 12, 2021 at 3:18 pm
manicosia
SubscriberI am trying to set up an initial levelset field in 2D using *IFCD_INITIAL_LEVELSET, option 2 (box). The parameters I put on the input deck do not seem to match the initial levelset field plotted with ls-prepost.
I am using:
*ICFD_INITIAL_LEVELSET
2,0.072,0.100,0,0.0786,0.1033
July 27, 2021 at 8:04 pmtslavik
Ansys EmployeeHello To properly investigate this, we would need the full input file, but it's not permissible to pass that data through the Forum. However, there are two major points to consider:
1) You need a DYNA version which has type 2 - this is available only in a Release R13 but that has not yet been formally released - it should be released in a couple weeks.
2) You need to have a least one ICFD_PART which has void material assigned to it and one which has fluid assigned to it.
Please check that and look for the imminent release of R13.
ref: 2021071410000082
Viewing 2 reply threads- The topic ‘ICFD_LEVELSET difficultyies’ is closed to new replies.
5664
1890
1414
1304
