May 15, 2026 at 5:26 pm
mberkman
SubscriberHi,
The Icepak model has good quality mesh (has several mesh regions) and converges well. Howver when I look at the temperature contours one of mesh regions seems to be disconnected from the rest, where temperature is trapped . Other mesh region results are as expected.
As any ideas how this can happen?
Thanks - Mert
May 25, 2026 at 2:53 pm
Prathik Devalla
SubscriberHi Mert,
This behavior usually indicates a connectivity issue in the model. Even if the mesh looks fine and converges, a region can appear “thermally isolated” if:There is no proper conduction path (missing contact or gap between bodies)
Materials or interfaces are not assigned correctlyI recommend checking the body contacts, shared topology, and material assignments for that specific region.
To help us investigate this in detail, could you please raise a support ticket and share the project files/screenshots? That will allow us to review the setup more thoroughly.
Best regards,
Pdev
6765
1330
1102
