Ansys Products
Ansys Products
I get this problem while installing Ansys Student version 2020 R1. How do I fix this?
    • nidig18
      "Unable to retrieve WB usage tracking, no WB usage tracking id supplied"
    • tsiriaks
      This sounds more like the error when you start Workbench rather than install it ?
      Please post the screenshot of the error and describe how you get tot his error in more details.
    • nidig18
      When i open Workbench after I have installed ANSYS and restarted my pc I get this. I have tried many times to install it. I didn't have a problem, when I dowloaded it to my laptop. It's apparently only a problem on my tower pc.
      Does your desktop user ID or computer name contain any special characters?
    • nidig18
      My Computer name is this
    • tsiriaks
      Can you post the output of
      set
    • nidig18
      I'm not sure of what you mean?`Can you explain it further?
    • tsiriaks
      In that CMD Prompt window, type
      set
      then, press enter and show us the output of it
    • nidig18
      I have changed my pc name to "Hjemme" instead of "Stationær".
    • tsiriaks
      There is no environment variables set from ANSYS install here. There was something wrong during installation.
      Try reinstall it again and if you still encounter the issue, re-post the output of set and also check if you have install.err file under (default) C:Program FilesANSYS IncANSYS Student
Viewing 9 reply threads
  • The topic ‘I get this problem while installing Ansys Student version 2020 R1. How do I fix this?’ is closed to new replies.
