July 28, 2021 at 6:48 am
zeanna317
SubscriberHi, im beginner in using ANSYS. Please help me to solve the error. I tried very simple beam and it's always error.
July 28, 2021 at 7:14 amErKo
Can you please post inline images of your model, boundary conditions, loads, and the error messages, because we are not allowed to download attachments.
Thank you
Erik
August 6, 2021 at 3:40 amAugust 8, 2021 at 11:38 ampeteroznewman
SubscriberClick on the Solution Information folder in the Outline. The main window will display the Solver Output. Scroll through that text or use the Ctrl-F keys to search for the word ERROR. Read what it says. You can copy/paste a few lines above and below that word into your reply.
August 10, 2021 at 4:05 amAugust 10, 2021 at 11:41 ampeteroznewman
SubscriberOkay, the solver didn't even start. I don't know why, so I hope someone like Erik might have a suggestion.
Is it just this model or is it the case that every model gives this same error?
August 12, 2021 at 10:38 pmzeanna317
SubscriberI try to every model and always error. I was thinking it is because of the application itself, but i dont think i did something wrong when i first installed it. I used explicit dynamics and it works perfectly fine. It is just static structural that cannot work. Should i reinstall?
August 12, 2021 at 10:39 pmpeteroznewman
SubscriberYes, if every simple model in Static Structural gives an error, you should try to reinstall.
Viewing 7 reply threads- The topic ‘I cannot solve everything in ANSYS Static Structural Workbench’ is closed to new replies.
5969
1307
