TAGGED: 2D, aerospace-engineering, cfd, engine, rocket
April 11, 2024 at 4:31 am
Zwernjayden
SubscriberI'm working off this (https://www.mdpi.com/2571-6255/6/3/100) research paper on modelling a hybrid rocket to determine its regression rate. I'm unsure how to model the fuel inlet. I thought it meant it should be a mass flow inlet, but now im thinking it could be a wall boundary condition with a surface injection of the fuel because it depends on the heat flux to the fuel wall, and im not sure you can get that if its an inlet.
TLDR: I'm not sure what a fuel wall+source boundary condition is in this paper in sections 5.2-5.4
April 11, 2024 at 9:56 am
Forum ModeratorYou can use a source term adjacent to the wall, and link the source to whatever drives the system.Â
Unfortunately Ansys staff can't offer much beyond that as rockets are on the list of things we're not permitted to assist with on the Forum.Â
April 11, 2024 at 4:42 pm
Zwernjayden
SubscriberSorry I'm still a bit new to Ansys. How do you define a source term. Would it be in a UDF?
April 12, 2024 at 8:40 am
Forum ModeratorSource terms are added in the cell zone panel, UDFs are one option to setting the value of the source.Â
- The topic ‘Hybrid Rocket Simulation’ is closed to new replies.
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
4597
1495
1386
1209
