March 26, 2022 at 3:47 pm
lyonsp4
SubscriberHello,
I am currently trying to run a harmonic analysis to see the displacement caused by an unbalanced shaft on a support, I have tried to place a rotational force acting on the centre of my geometry (See image Below), although every time I try to run the analysis I get this message and the analysis will not run.
"Coriolis effect is valid only in Full Harmonic."
March 26, 2022 at 3:52 pmpeteroznewman
SubscriberPlease reply with a snapshot of your Workbench Project Schematic.
If you have a Modal Analysis solution cell linked to the setup cell of your Harmonic Response, that is called a MSUP analysis.
When you don't have the solution cell of Modal linked, that is called a Full Harmonic Response analysis.
March 26, 2022 at 3:59 pmMarch 26, 2022 at 4:52 pmpeteroznewman
SubscriberIn Mechanical, please show the Analysis Settings, with the Rotodynamics Controls branch expanded.
March 26, 2022 at 5:32 pmMarch 26, 2022 at 5:58 pmpeteroznewman
SubscriberChange the Solution Method to Full Harmonic.
March 26, 2022 at 6:08 pmlyonsp4
SubscriberThank you for your help.
April 25, 2022 at 7:12 amtumulpurwar
SubscriberNice info..just commenting so that this post can save in my ansys account
Viewing 7 reply threads- The topic ‘How to turn Coriolis Effect on?’ is closed to new replies.
