March 20, 2020 at 2:31 ammatusSubscriber
HelloÂ
I am working on a transient boiling heat transfer problem on a vertical pipe. The saturation temperature in my case is 580K and calculated standard state enthalpy is 2.41e7.
should I use 580 k in the reference temperature value in material property tab of liquid and vapour
March 20, 2020 at 7:29 amAmine Ben Hadj AliAnsys Employee
Yes set the saturation temperature as reference temperature for material and adjust the material properties to reflect that.
October 6, 2023 at 6:50 amafrozalamSubscriber
I am simulating the plate heat exchnager with one coolant (water) is flowing over a flat plate with inlet temperature 282K and outlet temperature as 286K. and other fluid (refrigeratnt)Â which is evaporating on the other side of the plate with inlt temp 277.31k and outelet temperature 282.15k. the evaporation temp (dew) is given as 277.15k. May i know the saturation temperaure should be set as evapration (dew) point tmeperaure.?
ThanksÂ
Afroz
- The topic ‘How to set reference temperature in multi phase flow simulation?’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
1762
635
599
591
366
