February 20, 2021 at 7:29 am
knnn
SubscriberFebruary 20, 2021 at 6:30 pmknnn
SubscriberI think I resolved this issue, but am not entirely sure since now a new issue is popping up. What I did was I created another vacuum enclosure (small one) right around my transient moving bodies. The new issue I am running into that I have not run into before ever in previous versions of maxwell (perhpas its a hpc problem?) is The connection order of winding coil terminals is not set. I don't see any option to create an order either, what does this error mean? Why does it occur? How do I resolve this?.
n
February 23, 2021 at 1:11 pmNavya Chode
Forum ModeratornThat's strange! The error seems to be in no way related to band setup.nCan you create a copy of your model and try reassigning the winding terminals to each phase under Excitations?.RegardsnNavyanFebruary 24, 2021 at 7:45 pmknnn
SubscriberI don't understand, what am I reassigning the terminals to? The same phases? Am I just creating the same model in a different session?.Regards,nKoushiknViewing 3 reply threads- The topic ‘How to resolve Error in mesh mapping on band?’ is closed to new replies.
6600
1311
