how to plot result using 2 result combination? for example sliding at step1 – sliding at step 2
    • prasadmsonar
      I need to know sliding distance difference in step 1(press fit) and step 2( press fit+load). How to plot this?
    • Ashish Khemka
      You can use the user-defined result to define an expression that represents the difference between relevant results with each result item represented by an identifier. For example is the result item of interest is directional deformation in x-direction then following can be implemented:
      Regards Ashish Khemka
  • The topic ‘how to plot result using 2 result combination? for example sliding at step1 – sliding at step 2’ is closed to new replies.
