May 16, 2022 at 2:29 pmLuca_PatriarchiSubscriber
Hi all,
I am tring to perform a hamronic response of a structure using, as dampers, four springs attached to the basement. The problem is that a message comes out writing
"The system is solved without damping. This may cause very large peak harmonic responses around natural frequencies due to resonance".
How may I fix it?
May 17, 2022 at 12:38 pmViewing 1 reply thread- The topic ‘How to perform harmonic response in Static Structural with dampers?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Image to file in Mechanical is bugged and does not show text
- Timestep range set for animation export
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1406
599
591
555
366
