December 12, 2024 at 1:15 pm
December 12, 2024 at 2:17 pmRobForum Moderator
You need to use the correct magical incantations. That and change from "mixture" to "phase-2". I also advise calling "phase-1" something more useful so it makes sense when seen on post processing. "Phase-1-air" may be sensible.Â
December 12, 2024 at 2:29 pm
December 12, 2024 at 2:40 pmRobForum Moderator
Hang on, why are you setting the phase fraction in a cell zone? I'd missed that.Â
December 12, 2024 at 2:42 pmjackhc0609Subscriber
to set the volume fraction of vof .phase 0.5 volumefraction
December 12, 2024 at 2:46 pmRobForum Moderator
That's not how the VOF model works: it's a free surface tracking model. Have you done the tutorial? Â https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/flu_tg/flu_tg_vof.html
December 12, 2024 at 2:50 pmjackhc0609Subscriber
the two phases volume fraction can not be set in VOF ?
December 12, 2024 at 2:53 pmRobForum Moderator
They can, but that's not how you do it. Â Have you done the tutorial?
December 12, 2024 at 3:02 pmjackhc0609Subscriber
AHA it is in the inlet boundary condition to set the volume fractionÂ
December 12, 2024 at 3:24 pmRobForum Moderator
Yes, and also check the model requirements before setting 0.5Â Â
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1882
802
599
591
366
