February 2, 2021 at 3:58 am
Rashi
SubscriberHi,
I'm conducting an FSI simulation with Fluent and Transient structural coupling.
Influent I have set 0.01 (s) step size with 10 number of time steps.
I have finished the simulation in fluent and imported the temperature data to structural.
But I cannot get the time step values correct whatever value I put I get a question mark in the "analysis settings".
February 2, 2021 at 7:53 amRashi
SubscriberGot it solved!nFebruary 2, 2021 at 1:11 pmKarthik Remella
AdministratorAwesome! Thank you for this update. Good to know that you are able to move forward with your work.nGood luck!nKarthiknFebruary 2, 2021 at 1:56 pmRashi
SubscriberThank you, Karthik!nnQuick question does ansys have the capability of simulating the effect of time-temperature variation of materials? for example as for simulating stress-relieving occurred due to heat treatment?.nFebruary 2, 2021 at 2:13 pmKarthik Remella
AdministratorYes, you should be able to. For this, you will need to specify the variation of the material property with temperature as a table under Engineering Materials.nKarthiknFebruary 2, 2021 at 9:08 pmRashi
SubscriberHi Karthik,nBut Ansys does not have time dependency when it comes to material properties right? Where the rate of heat treatment can effect the mechanical properties?nViewing 5 reply threads- The topic ‘How to match time step settings for a coupled simulation’ is closed to new replies.
6650
1312
