TAGGED: driven-terminal, reference-manual, rotation-rotate
May 24, 2024 at 6:52 pmLexi BatrachenkoSubscriber
Hi! I have a few questions.
- How do you make vertical rectangles (2D sheets) in HFSS to use as ports? When I try to draw a rectangle out, I seem to only be allowed to draw it out in the XY plane. Is making it as simple as rotating it? If so, how do you do that?
- Additionally, can the each of the 2 ports in a 2-terminal device be connected to two separate ground references or does the ground reference have to be common?
- Can the ports have multiple ground references (i.e. each port has two PEC references)?
- Do the reference(s) need to be ground/PEC? (can all of the references be aluminum)Â
Thanks in advance.
May 29, 2024 at 2:25 pm
- The topic ‘How to make vertical terminal ports in HFSS’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- How to calculate eddy and hysteresis losses of the core?
- Simulation of capacitor combining eddy currents with displacement currents
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- On-chip inductor design
- Maxwell circuit – PWM
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
624
599
591
366
