November 17, 2021 at 12:16 am
Afifsena
SubscriberIs there any solution to know the mass flow rate outlet by ansys itself? Without input anything on outlet (even I don't have any data about the outflow/pressure outlet)
November 17, 2021 at 12:02 pmRob
Forum ModeratorThe CFD solvers require boundary conditions to then evaluate the flow field. Mass flow tends to fairly critical for this! What are you trying to model?
November 19, 2021 at 8:03 amAfifsena
Subscriberthis my example project (from the complex one), i want to know mass flow rate outlets (from the red) that given by ansys itself, because i don't know any data about the outlets (pressure, velocity, mass flow rate, etc). I only know the diameter outlet is different. In this image i choosed outflow type because i want to know the pressure outlet but in real field i didn't know the value of each flow rate weighting, and that cause the mass flow rate from report has same value (0,5 kg/s)
November 19, 2021 at 9:54 amRob
Forum ModeratorWith that mesh it's more surprising that the model ran. You're using an outflow boundary too which isn't recommended: read the documentation to see what it's doing.
Do a few tutorials to see how much mesh resolution we use there, and then try again. As a hint, a velocity inlet and pressure outlets should give you a more reasonable result once you've fixed the mesh.
November 19, 2021 at 12:52 pmAfifsena
Subscriberthank you very much sir, can i know where is the documentation?
November 19, 2021 at 1:07 pmRob
Forum ModeratorClick on "Help", it's web based but the software has all the links built in.
November 19, 2021 at 3:57 pmAmine Ben Hadj Ali
Ansys EmployeeCrystal Ball and I can provide it to you without any runs :)
Mesh is awful (sorry) but you need to start from there :)
Viewing 6 reply threads- The topic ‘How to know mass flow rate outlet without input anything on outlet boundary?’ is closed to new replies.
2788
965
851
599
591
