Ansys Products
Ansys Products
How to get the position of selected nodes in apdl using vget command?
    • Mehdi Baghaee
      How is it possible to get the position of some arbitrary selected nodes (e.g. attached to a specific area) within an array in apdl?
      Note that *VGET, NPOSX, NODE,  1, LOC,  X command returns the position of whole nodes (in successive mode) instead of the selected ones.
    • harshvardhan.negi
      The  APDL command *VGET is executed on the previously selected entities. So if you have selected a group of nodes, and you need location of any one node, you will first need to resect that node so that only that node is selected and then run the *VGET command.
      Harshvardhan
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
      • Mehdi Baghaee
        Just to say that it does not work. I dont know why it returns the location of all nodes instead of the selected ones.
        You could check it through my following codes which returns a 484*1 array instead of 18*1 array.
        /BATCH
        /input,menust,tmp,”
        WPSTYLE,,,,,,,,0
        /NOPR
        KEYW,PR_SET,1
        KEYW,PR_STRUC,1
        KEYW,PR_THERM,0
        KEYW,PR_FLUID,0
        KEYW,PR_ELMAG,0
        KEYW,MAGNOD,0
        KEYW,MAGEDG,0
        KEYW,MAGHFE,0
        KEYW,MAGELC,0
        KEYW,PR_MULTI,0
        /GO
        /PREP7
        ET,1,SOLID185
        MPTEMP,,,,,,,,
        MPTEMP,1,0
        MPDATA,EX,1,,1e9
        MPDATA,PRXY,1,,.3
        MPTEMP,,,,,,,,
        MPTEMP,1,0
        MPDATA,DENS,1,,6700
        BLOCK,0,10,0,10,0,1,
        FLST,5,8,4,ORDE,2
        FITEM,5,1
        FITEM,5,-8
        CM,_Y,LINE
        LSEL, , , ,P51X
        CM,_Y1,LINE
        CMSEL,,_Y
        LESIZE,_Y1, , ,10, , , , ,1
        MSHAPE,0,3D
        MSHKEY,1
        CM,_Y,VOLU
        VSEL, , , ,       1
        CM,_Y1,VOLU
        CHKMSH,’VOLU’
        CMSEL,S,_Y
        VMESH,_Y1
        CMDELE,_Y
        CMDELE,_Y1
        CMDELE,_Y2
        WPSTYLE,,,,,,,,0
        FLST,2,44,1,ORDE,12
        FITEM,2,1
        FITEM,2,-11
        FITEM,2,122
        FITEM,2,143
        FITEM,2,153
        FITEM,2,-161
        FITEM,2,243
        FITEM,2,-244
        FITEM,2,267
        FITEM,2,-268
        FITEM,2,287
        FITEM,2,-304
        /GO
        D,P51X,ALL, , , , , , , , , ,
        ANTYPE,4
        TRNOPT,FULL
        LUMPM,0
        ASEL,S,AREA,,6
        APLOT,
        NSLA, S, ALL
        *VGET, NAPOSX, NODE,  ALL, LOC,  X
        FINISH
        Any suggestion?
