April 7, 2023 at 11:17 am
swu321
SubscriberI created the structure and have done the thermal simulation.
I can draw a line (path) anywhere inside the structure and get the temperature along that line.
But I also like to have a plot for the temperature of any cross-section of this structure. I tried construction geometry -> surface. But unlike the definition of path, I can define the start and end points, the surface does not have anything to define where the surface is located.
I am not sure whether I did it wrong, or there is another way to get the cross-section of the structure.
Really appreciate if anyone could help me.
April 7, 2023 at 5:27 pm
Chandra Sekaran
Ansys EmployeeConstruction surface is the right approach. The surface is defined based on a coordinate system. When you create a construction surface in the details window you can change the coordinate system. The surface is based on the XY plane of the coordinate system. You can find more on this in the documentation at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/wb_sim/ds_surface_const_geom.html
April 8, 2023 at 8:07 pm
swu321
SubscriberThank you for the reply. However, I am not able to access the document you mentioned since Ansys only provide this forum for academic license.
April 8, 2023 at 8:49 pm
peteroznewman
SubscriberUse the ANSYS installed on your computer to open ANSYS Help. Then copy and paste the text in the link above into the browser showing the ANSYS Help and it will take you to that page.
April 9, 2023 at 6:00 am
Akshay Maniyar
Ansys EmployeeHi DmArcher,
You can check the link in my signature to know how to access Ansys help.
Thank you,
Akshay Maniyar
- The topic ‘How to get the plot of temperature of a cross section in Ansys Mechanical’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3892
1414
1256
1118
1015
