November 6, 2024 at 8:22 amGUICADSubscriber
Is it possible to obtain a hexmesh instead of tetra ?
Thanks,
November 6, 2024 at 8:38 amDevendra BadgujarForum Moderator
Hello,Â
Are you talking about Refine mode here?Â
DevendraÂ
November 6, 2024 at 2:29 pmGUICADSubscriber
Hello Devendra,
Yes, in Refine mode.
November 6, 2024 at 2:44 pm
November 6, 2024 at 4:53 pmGUICADSubscriber
Ok, thank you.
Viewing 4 reply threads
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
591
569
525
366
