November 10, 2020 at 2:24 pmSumit_vjtiSubscriberI'm working on simulation of SAVONIOUS Vertical axis wind turbine (VAWT) using 6DOF dynamic Mesh technique.My simulation is working correctly, but the problem is I can't find how to get the rpm of the turbine.nIf anybody know how to get rpm or angular kindly help.nThanks in advancen
November 10, 2020 at 2:46 pmRobForum ModeratorThe solver knows the cell velocity so you just need to report either a function of x (y, or z) position of a cell or cells. n
November 10, 2020 at 3:24 pmSumit_vjtiSubscriberThanks for reply.nI searched the report defination option but couldn't find the option report the cell velocity.n n
November 10, 2020 at 3:40 pm
November 11, 2020 at 3:45 amSumit_vjtiSubscriberThanks for the help.nAs far as my understanding you are saying that I will have to create point on rotor which is function of X,Y and time. correct?n
November 11, 2020 at 9:34 amRobForum ModeratorNot quite. A point won't travel with the rotor. You will need to separate out a facet and report on that. n
Viewing 5 reply threads
- The topic ‘How to find out RPM of turbine’ is closed to new replies.
Ansys Innovation Space
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
599
591
565
366
