November 8, 2023 at 10:53 am
kavi.pradhap434
SubscriberHi,
Greetings of the day!
I am trying to export the mesh data from a shell mesh. I am able to export the elemental data, which contains, element no, element name, nodal no, only. I also require the shell thickness and material name or material no. How to export elemental data with material name and shell thickness?
Thank you in advance
Regard
kavi
November 9, 2023 at 4:53 pm
mrife
Ansys EmployeeHi Kavi
Please always let us know which Ansys product you are asking about. And what method did you use to export? Mike
November 9, 2023 at 5:04 pm
kavi.pradhap434
SubscriberI am taking about ansys mechanical application. I have created a named selection for all element in the shell mesh and right click export. Using this i have exported. Is there any other way we can do this?
regards
kavi
November 9, 2023 at 5:38 pm
mrife
Select the Solution object in the Mechanical tree, then in the upper right of Mechanical select the 'Write Input File'. If you have an assembly and only want some parts, then first suppress the unneeded parts then write the input file.
Mike
November 10, 2023 at 6:41 am
kavi.pradhap434
SubscriberHi Mike,
Thank you for the solution. It worked
- The topic ‘How to export shell mesh element data with material no and shell thickness?’ is closed to new replies.
5694
1890
1419
