How to enable viewing results on a beam?
    • elhamasadi
      In modelling a stiffened plate, I can not capture the equivalent stresses on the beam. Here is the contour plot I get:
    • Erik Kostson
      If you mean that you have beam elements for the lower part that are transparent in the image above, and that you can not see stresses there, go to the Solution (A6) ->under Beam section results set it to YES (see below).nHope this helpsnn
      nInsert a Beam Tool into the Solution branch. Then you can plot stress components in the beam. Read Help on Beam Tool for more information. Open ANSYS Help, then copy paste the URL below into the address bar of the browser.nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/wb_sim/ds_Beam_Tool.html?q=beam%20tooln
    • elhamasadi
      nThank you, I could overcome it.n
  • The topic ‘How to enable viewing results on a beam?’ is closed to new replies.
