August 8, 2023 at 4:01 amKawshik NathSubscriber
I want to design exactly the structure given in paper but I can't there is a hole generate between this pyramidal array.
For designing a inverted periodic array 1st I have to made a unit cell of inverted pyramid array structure after that I create it's period. Please give me a solution how can i make this structure fully a resemble of that paper.
Figure given into the paper:
Figure which i draw to simulate
Perspective view
August 8, 2023 at 10:54 pmDevAnsys Employee
Hello Kawshik Nath,
Try not to duplicate same question or posts. posting progres /continuation question in same post will get a faster response. Please refer this Ansys Insight: Ansys Innovation Space —- Forum and Feed
Suggestions are provided in your original post as response:
How to design a period of hollow inverted pyramid? (ansys.com)
You made progress in making the exact copy of the picture. By modyfying pyramid geometry or by adding a rectangular block between each pyramid layer is a solution.Â
Also, as replied in above post please refer this Understanding mesh order for overlapping objects – Ansys Optics to understand mesh order to make hollow pyramid.Â
thanks and regards
Devika
August 9, 2023 at 7:54 pmKawshik NathSubscriber
Thanks, Ms. Devika.
I’m redesign by using the aforementioned methodes. But here also, When i desgned using rectangle winthin the pyramid, I got abnormal result in reflectance curve. i.e, Getting abnormal oscillation in the simulation result.
August 10, 2023 at 5:33 pmDevAnsys Employee
Can you share more details?
August 13, 2023 at 6:38 pm
August 14, 2023 at 4:15 amDevAnsys Employee
Hello,Â
Please try to simulate longer time with smaller autoshutoff min. Also, is it possible to share the screenshot of final geometry also?
Is your simulation single wavelength? please check broadband result and see if the reflection curve is smooth or not.Â
August 14, 2023 at 7:37 amKawshik NathSubscriber
Do you want to see the screenshoot of FDTD geometry?
August 14, 2023 at 3:40 pmDevAnsys Employee
Yes. share a screenshot of final geometry picture. Provide maximum information single response.Â
I repeat, please try to simulate longer time with smaller autoshutoff min.Â
I am also suggesting you to set the settings of simulation similar to the example Silicon solar cell with TiO2 pyramid array – Ansys Optics.
Regards
Devika
August 17, 2023 at 6:23 pm
August 14, 2023 at 7:42 am
August 14, 2023 at 7:43 am
- The topic ‘How to design exactly that structure? Attached both paper and which I draw.’ is closed to new replies.
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Absorption cross-section of AuNR excited by prism-based TIR
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
1416
599
591
565
366
