TAGGED: #Design-Modeler-#catia, 3d-blade, 3dmodel, coordinate
September 4, 2024 at 8:36 am
September 9, 2024 at 12:57 pmRobForum Moderator
Have a look for "polyline" in here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/spaceclaim/Discovery/user_manual/file/r_file-operation_import-export_import-file-formats.html  You may then need to connect the edges to form a surface.Â
I've only seen this done reliably (ie with any set of data) with tools designed for dealing with medical models: tools by Materialise and Simpleware (Synopsys) which aren't Ansys products. It's a very specialist function, and historically resulted in stl format after a significant amount of data processing.Â
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
599
591
565
366
