How to calculate Force to be applied by a electromagnet to Stop a Hollow Drum which in rotation
    • ragu4u
      The system have to parts.- 1.Drum 2. Pole. This two parts are rotational elements. nFirst the pole rotates in 2000rpm, Then I want to rotate the drum in same speed. HENCE I give excitation to pole and made it-Electromagnet. Hence pole will attract drum, it will lead to rotation of Drum also. nMy question is n1.How much force to be given by pole to rotate Drum witb same speedn2. For that force how many current I should given3. Is this simulation can view in Ansys Maxwel?.
    • Karthik Remella
      Administrator
      Hello,nThis is a duplicate post. For better and streamlined support, please refrain from creating duplicate posts. nYour question is being answered here.n
      https://us.v-cdn.net/6032193/uploads/B5YQJ5BJT71U/16037762661038363133285462626754.jpgThe system have to parts.- 1.Drum 2. Pole. This two parts are rotational elements.First the pole rotates in 2000rpm, Then I want to rotate the drum in same speed. HENCE I give excitation to pole and made it-Electromagnet. Hence pole will attract drum, it will lead to rotation of Drum also.My question is1.How much force to be given by pole to rotate Drum witb same speed2. For that force how many current I should give3. Is this simulation can view in Ansys Maxwel?/forum/discussion/21594/stuck-with-electromagnet-design
      Thank you.nKarthikn
  • The topic ‘How to calculate Force to be applied by a electromagnet to Stop a Hollow Drum which in rotation’ is closed to new replies.
