February 16, 2023 at 4:00 pm
February 21, 2023 at 6:06 pmHDLIAnsys Employee
Hello Kenny,
We could use and enter pwl(ds1,time) in "Angular Velocity", and ds1 is dataset of Maxwell design with time function.
Howard
April 16, 2023 at 8:58 amKENNY WUSubscriber
Hello Howard,
How to use pwl with load torque varies with rotate angle(will higher than 360 degree)?
I used pwl(loadtorque, Ang), but the report of load torque isn’t change by the time
Is “Ang” to be used in this condition? or another variable?
Thanks a lot
- The topic ‘How to assign the band to rotate with time depends angular velocity’ is closed to new replies.
Ansys Innovation Space
- HFSS Incident Plane Wave excitement mode
- Question for Maxwell
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- How to customize pulse waveform and injection site in microstrip array
- 180 Degree Phase Shift When Measuring S21
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
543
523
225
209
