How to apply tension in cable?
    • omar30
      Hello
      I am modeling a cable as beam element what is an alternative of applying tension instead of bolt-pretension? Since after static structural step I am considering the modal and harmonic response leading to some errors in natural frequency.
      For example, applying bolt pretension leads to a good result for stress, but in terms of natural frequency first value is 0 in harmonic response.
      I appreciate any type of help
      Use the INISTATE command to tension a cable without using a Bolt Pretension load.
      https://www.google.com/search?q=site%3Aforum.ansys.com+inistate+cable+tension
  • The topic ‘How to apply tension in cable?’ is closed to new replies.
