LS Dyna
LS Dyna
How should I set it up to see the solid profile?
    • Tim T
      I used the S-ALE algorithm to complete the solution, and when I used LS PrePost to view the d3plot file, I found that the fluid profile is hollow. How should I set it up to see the solid profile?
    • Nanda
      Hello Tim,
      Could you check if you're using Wireframe visualisation? If so, please switch the rendering mode from “Outline” or “Wireframe” to “Solid” or “Shaded.” This setting is in the graphics window or under the part display menu in LS-PrePost. Also, could you upgrade to the latest LS-prepost we offer if you're using an older one?
      https://www.dynasupport.com/howtos/material/ale-history-variables
      Nanda.
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
      Have a look at our public help documentation website: Ansys Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
    • Ram Gopisetti
      Hi Tim,
      Given that your setup and run are correctly configured, in LSPP, under the SelPart option, you should see entries listed as (Ale). Alternatively, you can apply the Fluid(Ale) filter and then select the appropriate body to post the results.
      Cheers,Ram
