Electronics
Electronics
How do I make Bulk Conductivity a variable?
    • ixg90
      I would like to run a simulation where I vary the Bulk conductivity of a copper conductor. The default value is 58,000,000 Siemens/m, and I would like to run a variation from roughly 10% below to 10% above default.
      Typically in HFSS, I can type a variable name into a box, and the software recognizes this as a variable and asks for the default value. I tried this when creating a new material in the material list, and was told that my variable "copper_conductivity is not a defined variable name in this context".
      Next, I went to HFSS -> Design Properties to create a new variable. I made a new variable with units "S_per_m". I again tried to type this variable name into the materials property box, and got the same message.
      How do you vary a material property such as bulk conductivity?
    • Chinmay T
      Define the project variable and use it to vary the material property.
      Please go through this video for more details on how to define and use project variables.
      Thanks Chinmay
  • The topic ‘How do I make Bulk Conductivity a variable?’ is closed to new replies.
