TAGGED: ansys-hfss, ansys-q3d-extractor, error, frequency-sweep, hfss, pcb, q3d, scattering-matrix
October 17, 2024 at 7:57 am
m.harasim
SubscriberHello,
When using the "Use Q3D to solve the DC point" option, within a frequency sweep in the HFSS, the simulation returns the following error:
The simulation profile contains the following information:
The model consists of a PCB cutout and additional bodies: part of a housing, connector enclosure, a few wires (geometries united with the connector pins) and a copper bar connecting the housing to a reference plane:
The aforementioned reference plane is a "Perfect E" boundary assigned to the bottom face of the airbox:
There are multiple lumped ports and RLC boundary conditions defined between various copper lines/planes of the PCB:
My goal is to compute a scattering matrix of the PCB, to be then used in a transient analysis (utilizing the Nexxim solver in the Circuit environment). Hence I need to sweep the frequency from the DC up to the end of the bandwidth of interest (400 MHz):
The HFSS mesh is computed for the 400 MHz:
I haven't found any details regarding the error message. Could you please explain the meaning behind it?
Best regards,
Maciej
October 17, 2024 at 10:51 am
alexandre-antoi.bourrieau
SubscriberI got same problem... hopping someone will help us !
May 21, 2025 at 9:44 pm
shahidaziz_khan
Subscriberany solution to this problem?
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Simulation of capacitor combining eddy currents with displacement currents
- Compute near field simulation with current
- HFSS: Using Q3D to solve the DC point
- Double-sided LIM external circuit error
- Ansys Resonance simulatioin error
3190
1024
962
858
798
