Ansys Products
Ansys Products
HFSS Impedance under a specific plane section
    • JINZHI YAN
      I have a question, how to view the impedance at a specific location in HFSS。
      I have used the deembed function on the wave port, but when I change the distance in the deembed setting, I still cannot see any change in the impedance of the distance in the result.
      How should I set it up so that I can see the impedance at different cross-sectional positions? I want to know what the impedance value of the device is at the XOZcross-section at a specific distance.
    • Aymen Mzoughi
      You can define the deembedding distance as a post-processing variable and then sweep the values in the report:
  • The topic ‘HFSS Impedance under a specific plane section’ is closed to new replies.
