Help with wind turbine analysis for university project
    • powellp4
      I am currently analysing the windflow around a wind turbine I've designed for a university project. I followed this video. With the central part with the turbine in it when I run the anlysis and view results there is no flow in it, only around it. I've tried a few different things, coupled walls, implicit mesh, but I'm still struggling to get any results out of the centre. Any help would be appreciated.
      I've attached the model. Thanks
      Please post the images. Staff are not permitted to download file nor follow links. If you've not defined the interface correctly Fluent will see that as a blockage.
